GT4 caliper piston dust boot replacement
- Thread starter GT42023
I found this video albeit a different car & hoping I can do it as simply this
If anyone has replaced the dust seals, keen to hear if you were able to do this with the pistons still in place.
Jeff
https://www.design91.uk/p/porsche-9...MI-dST5duLkwMVpZVQBh06kyqxEAQYAiABEgKxlPD_BwE
Arcam-Storm
Arcam-Storm
The reason for not removing the claiper would be just the extra work required plus a full brake bleed would then be needed, if they could be done insitu then a bleed could be avoided.I’m afraid that I can’t advise, but isn’t it going to be tricky getting into the limited space between the disc and the caliper when the pads have been removed to see what you’re doing? I can’t see any disadvantage in removing the caliper to get full access, but maybe I’m missing something.
Jeff
