GT4 alternative brake discs
GT42023
I've done 19 track days & although the stock discs are within tolerance thickness wise, the cracks from the holes are probably going to render the discs needing changout.
I'm thinking of trying slotted EBC 2 piece discs & Endless pads this time. I ran the stock discs with DS3.12 pads for the last 12 days on circuit.
Has anybody used the EBC discs?
Another alternative is PFC, I know Twinfan uses these.
I know a lot use Girodiscs but looking online these seem to corrode & look rubbish in a short time in the non contact areas.
I have used the fulling floating disks from EBC on two previous (non Porsche) cars that were used a lot on track and they were excellent, I can also recommend AP Racing, Alcon may also be an option.
That's great thanks, next question is did you experience any rattle with fully floating discs?
I like the idea with the current EBC 2 piece discs that they come coated in black so hopefully won't show corrosion in non contact areas.
They were silent in operation and their wear rate was good with race pads like the Pagid RS29 compound I normally run, plus they are made in the UK :)
how are the ceramic pucks holing up ? do you change pads 1/2 worn or swap pads over ?
I think 19 track days I would be going or a AP set up with some better callipers.
Calipers should be covered under the extended warranty, if you're running it? The standard brakes are great for my level of driving with upgraded discs and pads, so I'm just keeping them and if the pucks fail then I should be able to claim for a new caliper....
Callipers won't be covered.
    • Uneven piston wear These indicate track-induced thermal overload → declined.
      :) and you def won't be covered if you using after market pads or disks. which will be every on who tracks a Gt4.
Hmmm. I know a guy who tracks a lot and has had a caliper or two under warranty, but they were using standard discs/pads.
Could depend on the OPC I guess, and Porsche would need to be confident that the issue was caused by the non-standard discs/pads. You could argue using stock items would still cause the same issue.
I guess I'll find out if it's an issue if and when my pucks collapse! ?
The pucks look fine on mine but the rear dust boots are toast which I'll be replacing soon. I was running standard disks & Ferodo DS3.12's.
I have used the fulling floating disks from EMC on two previous (non Porsche) cars that were used a lot on track and they were excellent, I can also recommend AP Racing, Alcon may also be an option.
Installed & used on track 4 times now. I'm using RPX pads at present which have been great & have been pretty much silent on the road since the first trackday in them. The discs seem great but I think the RPX pads will be done in 5 to 6 days on circuit. Have Endless MX72 plus pads ready to install & hoping for a good life out of the discs without the cracking issue from the stock discs drill holes.
I am waiting for EBC to offer the 2 peice discs for the GTS, they recon they are a few months away yet. I have found 2 peice units from Paragon Performance in the US that do offer them for the GTS but the shipping to the UK really jacks the price. Glad the EBC discs are working for you.
