GT3 wing
- Thread starter joafog
dereksharpuk
ORIGINAL: dereksharpuk
Unless you want to get airborne you should not fit any rear wing to a 911 without the correct front splitter.
I have also bought the original GT3 frontbumper!
//Joacim
You will need the car's electronics re-programmed to select fixed rear spoiler option. This will stop the diagnostics nagging you that there is a problem with the retractable third brake light. Porsche Centre charged me £30 for this 5 minutes of customer service!
Is it true that this could be a problem?
//Joacim
You should get the front splitter/ Rear Aero as a set and fit them together.
The Rear aero does create down force, without a carefully matched front spoiler and splitter that will create a greater degree of down force then what will happen is the already light front will get lighter and the already heavy rear will get heavier - Quite a risk of the front getting too light to get effective grip and steering on the front at speed...........
If they are a matched design then overall down force front and back is higher at speed giving the car more stability and more control. Normally there is a bias to give slightly higher front down force to aid turn in and reduce bounciness at the front hitting bumps at speed. I noticed an improvement in front stability and steering when I fitted mine.
The two obvious choices are a) an OEM or TUV replica 997 Aerokit b) An OEM or TUV Replica GT3 Aerokit. Any reputable manufacturers Aerokit should be fine if TUV approved, so Cargraphic, Manthey etc are fine.
Just make sure you fit the whole thing, front and rear before using it. [
Faz
http://i52.photobucket.com/albums/g19/Geoff997/Hamann4.jpg
http://i52.photobucket.com/albums/g19/Geoff997/Hamann1.jpg
The complete package has TUV approvals etc. so no worries regarding aerodynamic imbalance. The rear wing retains the original deck lid and simply bolts on in place of the retractable one, which is not the case for your's.
The black panel in your picture includes the rams etc. for lifting the original spoiler and will not fit or be required. You will need to refit the engine fan assembly and associated wiring. The other part of the wiring harness will have to remain but neatly tied back and secured.
And yes the re-programming only took 5mins, long enough to plug in the Porsche diagnostic laptop and press a few keys!
