greddy profec
- Thread starter u63af
ORIGINAL: u63af
Hopefully the car will be a bit quicker when I have this with a tial dpw aswell.
It will be a LOT quicker but more importantly with less lag and a smoother delivery [
sawood12
ORIGINAL: u63af
I have bought the promax 1.2 bar chips which seem to be suitable for running bigger injectors up to 1.2 bar. Hopefully the car will be a bit quicker when I have this with a tial dpw aswell.
You wont be disappointed. I got Promax 1bar chips and noticed a significant improvement all through the rev range. My chips have maps for 55lb and 68lb Delphi injectors (don't know if they can be used with other brands of the same flow rate) selectable via the FQS switch so I guess yours will be the same.
1.2bar on stock injectors will be getting close to their max duty cycle but there are plenty of chips about that use stock inj to about 16psi.
JamesO
What sort of air fule gauges are you gi=uys using. I had a splitfire on in my old 924 turbo and it was s***.
Are there any kinds that can use our existing lambda sensor?
Sandy
[/quote]
I use a VEMS wideband controller with bosche wideband sensor.
It has inputs for RPM, EGT, intake temperature and manifold pressure. So you could datalog exactly when you are too lean.
ORIGINAL: JamesO
......Are there any kinds that can use our existing lambda sensor?....
AFAIK any narrow band should work.
