924Srr27l said:
As there is no significant initial pressure change in getting the pads to contact the disc initially the claim that ptfe lined hoses are faster is erroneous.
Following the initial contact phase then I agree a system without damping will have a more linear application. Assuming both systems deliver sufficient pressure to lock the wheels (if ABS wasn't present) then the (possibly) more compliant (rubber hose) system will potentially have a longer pedal travel to take up the possible expansion of the rubber hose when looking to apply ultimate pressure.
My comment is based on the assumption that you don't want to apply ultimate pressure, because the brakes will lock. Brakes aren't a switch; you don't want to apply ultimate pressure instantaneously. So there is a middle ground between no brakes and instantaneous brakes which is the optimum. The optimum brake application (in the considered opinion of people I respect -YMMV) is in the shape of a poo ie the change from none to the required amount is a tapered curve.
I understand the advantages of ptfe lined hoses but I also appreciate there can be advantages in correctly designed rubber hoses on a road car. You seem intent on looking at the absolutes of everything in order to argue against these potential advantages to a road car.
You also have to consider the difference between driving on a track and on the road - even "press on driving on the high way" is completely different to on a track. On a track you go round and round repeating the same thing over and over and doing more and more until you frighten yourself. If you brake too late or too hard you just don't do it next lap. There is almost no situation where you need to do an emergency stop. And you are 110% focused on the job in hand. Driving on the road is nothing like that, when you are minding your own...STOP!!!
I can see both sides, you don't appear to have that capacity.
