Jonny944CS
Hello all,
I have tried to search for an answer to this, both on here and Rennlist; is there anything special about the genuine balancer shaft belts?
Porsche are asking nearly 4 times the price of belts by conti tech and Dayco. Contrastingly the OPC prices for Cam and auxiliary belts are within 10% of the alternatives.
In the past I have used Dayco belts from ECP (I think), however having had the tension set and re-checked by both a leading independent and myself using a borrowed gauge, I end up with what always seems, to me, to be a strong belt whine.
Does anyone know who makes the genuine belts?
I have experienced parts from an OE manufacturer to be produced differently to the original Porsche spec, for example brake disks without the any anti corrosion treatment on the surfaces not swept by the pads, perhaps this could be the case here?
Maybe the Porsche spec stipulates the rubber has some kind of expensive silicone additive to reduce noise"¦.? If this was to be true and people have experienced quieter running with genuine belts, perhaps the extra cost could be justified for such a key engine part.
