Gearshift bushes?
- Thread starter RSGulp
bush at the bottom of the gear lever pivot
bush for the gear rod mount
gear lever spring plate and springs plastic guide plate
Plastic guide plate
I did the job 3-4 years ago and bought the bits from the Porscheshop. The parts cost about 50 quid and job took about an hour once I had mastered the springs. My car had similar problems to yours and I was considering fitting a short shift kit, but several people (including a couple of racers) said that fitting replacement parts would give better results. Apart from the 915 gear box being slightly agricultural in feel the repair worked great and I haven't given the short shift kit another thought.
Rats
ORIGINAL: johndglynn
Buy the bits from Porsche, they cost peanuts.
Thanks for the input everyone. John - roughly how many peanuts did the parts cost you from Porsche?
ORIGINAL: Rich Claridge
Stand by Rich, will dig the receipts out later, think I might also have listed the prices in my running report.
I plan to tackle it tomorrow and will probably doo what I usually do and cast the Haynes to one side and get stuck in...
Quick question - I've pulled up the rubber boot at the base of the gear lever. This exposes two nuts holding down the spring plate. Do I need to remove the centre console in order to expose the bolts holding the whole assembly in? Or is it a case of unscrewing the 'pivot pins' which the lever sits acrossto get down to where the ball socket bush is? I'm guessing the whole assembly needs to come out.
There's a good procedure available on Pelican for adjusting the shift coupler when your new bushes are sorted.
...And I guess a long magnetized screwdriver may come in handy for any dropped nuts (fnarr fnarr).
Cheers,
Rich
Puberty not a requirement for 911 ownership mate, I know a few little boys who bought themselves a petrol-powered Porsche when they should have stuck to the pedalled variety a bit longer, so if the nuts don't drop over the weekend then don't worry about it too much....one day lol [8D]
