scam75
Well-known member
Afternoon all
Well finally got the AOR box apart and its bad news. Full gear set, crown wheel and pinion is toast. [
] The LSD has survived and I can get a full gear set from somebody who has contacted me. I need a crown wheel and pinion. Does anybody A:know if the crown wheel and pinion is the same as in any 944 box, any turbo box? B: Have one!
I do have a non LSD turbo box in the car just now but it is quite noisy. The crown wheel and pinion may be ok, this box although noisy, hasn't run dry on oil to the best of my knowledge and it may well just be noisy bearings. So I could remove this box and get it opened, hope it is the bearings, replace them, chuck on the LSD and we should be all good. However this leaves me without a car, and also there is the risk that the crown wheel and pinion may be no good. So really I want the AOR box fixed and ready to swap back over. Bit of a quandary really. If I could get a decent crown wheel and pinion I would be over the moon!
Thanks in advance
Stuart
Thanks in advance
Stuart
