gearbox oil
- Thread starter Guest
Peter Empson
George Elliott
I changed it at about 90k miles, they whine a bit so good oil is important perhaps?
On the same subject the CV Joints get a bit dry, you may consider repacking the grease in them
George
944T
964
Didn't make any difference! But gave me peace of mind that my toy was being looked after well (bless!)
Wigeon Incognito
It made a positive change to shift action, but didn't make any change to my transmission noise.
Mine came from Fluke Motorsport whose service was excellent, even managing to arrange quick delivery when they were out rallying in Barbados. It is sold in quarts rather than litres though so you'll have to buy three bottles.
Then again, using most peoples fill method (fill until you see it coming out rather than a little way below the fill hole) you would need more than two litres anyway.
George - can you just release the gaiter to repack the CV joint, or is there more to it?
zcacogp - do you know which Vx stuff exactly you used? I have a Vx trade club card but not a 944 workshop manual. I'm pretty sure it should be 75W90, but no more than that.
ORIGINAL: ians
Thanks all - sounds like a job worth doing.
Definately.
The service interval is 48k miles or four years (though I personally change mine every 2 years as fresh oil is far cheaper than a gearbox rebuild).
Yikes, if a car really is on it's original oil [&o]
dave364634
seem to recommend
http://partsforporsche.co.uk/osc/swepco-gear-80140-p-1192.html
tr7v8
Me being one of them! Probably one of the most significant changes made to the car. The change quality & lack of noise was amazing.ORIGINAL: dave364634
http://forums.tipec.net/viewtopic.php?f=25&t=5684&view=previous
seem to recommend
pauljmcnulty
And, check you can remove the filler before the drain.
dave364634
tr7v8
Yup & I'd go with a semi or full synth if you canORIGINAL: dave364634
so either of the oils in my first post will do the job, and i must avoid gl5?
I went from Castrol Syntrax 75W90 to Swepco. You could class the Castrol as being the correct spec of oil, whereas Swepco is a thicker lubricant, recommended by enthusiasts for our gearbox.
My car is a 220T with LSD and external oil cooler factory options that's done 75k. Second gear synchro is worn.
Driving away cold the Castrol requires less force to affect a gearchange.
After driving for 10-15 mins the Swepco warms up. The Swepco gives a smoother and slightly lighter change once warmed through than on Castrol.
Its a heavy change down into second. Since switching to Swepco I've always preferred to double declutch my changes until the gearbox oil has warmed through as it is a lot lighter thereafter.
I find that changing up gear in excess of 3000rpm gives a lighter change than my pootling around mode where i change up at 2000rpm. In fact above 3000rpm I really like the weight and feel of my cars gear change.
I bought the Swepco from Berlyn Servicees, many years ago, so can't advise on price.
I use a good quality regular oil for around £4/litre and change it every couple of years (needs to be done again). That's in a road-going S2, driven enthusiastically.
geoffbateman
pauljmcnulty
