Hi all,
I am looking to fit some aftermarket gauges to the car as I have problems with the standard ones.
1. Boost gauge - maybe not accurate enough.
2. temp gauge, throws a wobbly now and again and scares the pants off me, I have had a new temp sender installed but still tends to go right up into the edge of the red at times then drops suddenly to where it should be.[8|]
I have also thought about a vacuum gauge so that leaks can be detected - is it actually possible to measure the vacuum or even worth it on this car.
What are the most suitable gauges to buy and complement the interior.
I have thought of pillar mounted or wondered wether Flaming Eye could manufacture a heads up display sort [
What are the other types that should be considered.
Thanks in advance
Jason
Thanks in advance
Jason
