Whilst using the passenger footwell accessory socket a few days ago to run an air compressor to top up a couple of tyres the pump stopped working.
It carried on working through the cigarette lighter but not the other accessory socket in the compartment behind the handbrake.
I thought it would be a simple case of fuse replacement. When I got to the fuse box by the drivers feet the little map I found there bears little resemblance to the fuse layout. So, I took every fuse out and inspected each one - none were blown! The sockets still don't work (except the lighter socket)
So, I'm confused! (bad pun!)
Can anyone with a Gen 1 997 point out by whatever means seems most appropriate which fuse it should be or point me in another direction if that seems more appropriate?
Note on operation
