Fuel Tanks (again!)
- Thread starter paulf968
Tam Lin
ORIGINAL: 944 man
A 924S is to all intents and purposes a series one 944, the fuel tanks are interchangeable. Fitting a series two 944 plastic tank is a far larger undertaking, although it is perfectly possible.
Simon
Yep, definitely possible. And a 924S with an 88 Litre tank has a cruising range of around 600 Miles. Ask me how I know ;-)
bertelli_1
The only real obstacle is the removal of the welded crossmember, Sean's is quite a late car & had the captive nuts for the 944 gearbox support under the welded part. Ans the mounts that fit in the centre of the tank. An earlier car may or may not have these mounts fitted, you'll only know when you get in there. Another problem could be the fuel line routing as they run along the other side of the floor on a 944.
bertelli_1
Tam Lin
Swapping the fuel lines was fortuitous, as after 20 years they looked decidedly second hand, and I think I had one of the last sets of 944 OEM tubing for certain parts..
The rear of the 924S is all 944T now: the tank (nb a 968 one doesn't fit to a 944 gearbox easily), G/Box with LSD and cooler, the infamous brakes with guaranteed plate-lift & driveshafts..
944 man
This is probaby only ever going to be a theoretical question, because Im struggling to find a turnkey 944T at sensible money, so the chance of fitting a 968 driveline is pretty slim..... [
Tam Lin
ORIGINAL: 944 man
Am I correct in thinking that you could fit a 968 transaxle to your car now? By that I mean that a 968 trans will fit a car with a series two plastic tank, but had you fitted a 968 plastic tank, then the 944 trans wouldnt fit?
This is probaby only ever going to be a theoretical question, because Im struggling to find a turnkey 944T at sensible money, so the chance of fitting a 968 driveline is pretty slim..... []
AFAIK correct: If I wanted a heavier gearbox with a famously fussy pinion bearing assy, together with an extra gear that would allow my 924S to fly (literally, due to the aerodynamics north of 140 Mph), yes. Of course I'd hope someone does the decent thing and shoots me first..
