Fuel pipes
- Thread starter Richair
Thanks for the prompt response, I had a good look but their is no practical advice for the home mechanic. The threads i found were mainly discussing the pros and cons of OEM hard lines and flexible pipes and geared towards someone else doing the work. I know that RPM and PROMAX do kits but it would be very easy to get the kit made up by a local hydralics company
The reason for the post is that I want to find out the diameters of the main and return pipes and information and recommendations concerning the banjo joints. Also the rough length of the pipes and any tips to fit without having to remove various panels would be helpful.
Jason
Check out the Arnworx website for all the fitting sizes, you can buy them from them too if you don't mind waiting for them to be shipped over.
Has anyone made up braided replacement fuel pipes for their 944S2? I'm planning to have them made and change them myself and before I start I want to know if anyone else has done this and can give me any directions? If so does anyone know the lengths, diameters and connections that are required? Or does someone sell a reasonably priced kit?
Jason
Also a good place to mention my learnings from this morning. Pirtek is often mentioned as a hydraulic supplier that can cut off and remake swaged fittings and so on. I took my oil cooler hoses in this morning to have them repaired, and was told that they have changed their policy (only a few months ago) and are no longer allowed to reuse fittings. They were able to recommend a local company who were happy to do the work.
As said, the feed line is 10mm and the return is 8mm so go for the closest AN size to that AN-8 and AN-6 IIRC. If you're doing the whole run then it would be worthwhile doing it in Teflon braided hose for longevity - the same eBay shop sells decent aluminium hose to body clamps too.
As Rich states, the Arnnworx site will give you all the fittings sizes you need, at the fuel rail it's just a jubilee clip (buy a nice anodised hose finisher one) for the return line and you'll need an adaptor for the feed line to the damper (again, torques sell a Bosch fuel regulator adaptor in a variety of colours). I'm a little hazy on the fuel tank return and pump fittings.
My friend replaced the full lines with black nylon overbraided Teflon hose and black AN fittings and it looks very OEM - think the cost was around £100 too.
