Fuel lines
- Thread starter colin944
timmyturtle
nick9one1
pauljmcnulty
timmyturtle
pauljmcnulty
I'd go back to the supplier, ask him to look underneath and assure you they aren't faulty. Possibly suggest he lights a match if he's that convinced.It's like the fumes are seeping through the hoses. Annoyed as they weren't cheap and are quite possibly useless.
944 man
SAE J30 R6? This is susceptible to ethanol degradation, as far as I am aware - hence my initial post, as it happens. SimonORIGINAL: nick9one1 I read a good thread somewhere about types of fuel hose and another 944 owner that had problems with fuel lines seeping after a year. He listed fuel line specs like SAEJ30. I cant find it anywhere now though!
Hilux
[link=http://www.ebay.co.uk/sch/i.html?_nkw=copper+pipe&_sacat=0&_sop=15&_dmpt=UK_CarsParts_Vehicles_CarParts_SM&_odkw=copper+brake+pipe&_osacat=0&_trksid=p3286.c0.m270.l1313]8mm and 10mm readily available in copper on e-bay[/link] [link=http://www.ebay.co.uk/sch/i.html?_nkw=kunifer+pipe&_sacat=0&_sop=15&_odkw=copper+pipe&_osacat=0&_trksid=p3286.c0.m270.l1313]Also in Kunifer[/link]ORIGINAL: colin944 Tried to buy copper fuel line today. Cant get any anywhere. What does everyone else use? Also what are the proper sizes for the feed and return pipe and what size are the screw in conectors?Any info will be gratefully recieved.
Hilux
Depends how exposed, normally they are run in protective indents and if they get squashed the car has had serious damage and if the contact points are isolated there are no corrosion issues but Kunifer is a bit harder. I use it all the time, its self supporting so doesnt need as many support fixings as flex pipe.Copper isn't usually the best choice as it is a soft metal and doesn't resist knocks like other metals. My VW Golf lines were replaced with some sort of steel alloy that resists corrosion .
Then change them! If it's the high pressure side you`ve got about 45psi going through them! Also with braided hoses you cant see any degredation (or leaks) -I replaced mine with braided hoses the whole length. I'm not happy about them,they smell of petrol,but there is no leaks!
nick9one1
nick9one1
nick9one1
could you elaborate on the diameter of hose and connectors you used? ThanksORIGINAL: timmyturtle I replaced mine with braided hoses the whole length. I'm not happy about them,they smell of petrol,but there is no leaks! Copper isn't usually the best choice as it is a soft metal and doesn't resist knocks like other metals. My VW Golf lines were replaced with some sort of steel alloy that resists corrosion .
