James_G
ORIGINAL: zcacogp
1. DON'T THROW THE OLD FRONT UNITS AWAY! Someone will use them for a Koni job. (Fitting the koni units involves cutting those front dampers up and installing the new koni inserts inside them.
Ah, an excellent suggestion and having spent all day under the car, I've spent the evening in the garage cutting the old dampers to size to fit the Koni inserts using the Paragon Parts instructions available here. So they are all ready to take some new inserts, although of course if those instructions are wrong.........[
ORIGINAL: zcacogp
2. DO get it geo'd. Changing the dampers means the wheels are pointing in every direction but the right one. When I did mine, having the geo set after fitting the new dampers made more difference than changing the dampers. Really. There are posts galore on here about the 'ideal' settings, but I can let you have the details of what mine is set to if you want (I headed for what are generally seen as being on the aggressive end of what you'd choose for road use, and I think it's superb.)
Definitely and in fact it was all booked in for it, but alas I've had to postpone because neither of the OPCs nearby had the camber bolts in stock, so I am having to fit them tomorrow afternoon. Geo then will be soon for sure, but yes I'd definitely be interested in your geo settings Oli, has having driven round the block in yours, I thought they were superb too!
