fog light screws
- Thread starter foosh944
(I've never had an S2}
nick9one1
Measure the length (probably around 60mm).
Then buy something like this!
http://www.ebay.co.uk/itm/M4-x-60-STAINLESS-ALLEN-BOLT-CAP-SCREW-10-10-EX-FREE-/220597721462?pt=UK_DIY_Material_Nails_Fixing_MJ&hash=item335ca61976
or if you want to keep the inferior phillips head
http://www.ebay.co.uk/itm/M4-x-60-Stainless-Pozi-Pan-Head-Machine-Screws-x10-/360191310255?pt=UK_BOI_Metalworking_Milling_Welding_Metalworking_Supplies_ET&
jonnyporsche
BlackMagic
But the full answer is to drill off the heads using much larger drill bit and then grab the remainder of the screw in mole grips to get it out. Be careful as the plastic of the housing is often less robust than the rusty screw! I ended up removing the housing from the bumper, drilling out the screw from the rear (as it is much easier to centre the drill on a flat surface) and then cutting a new thread using an M4 tap. Stainless steel capheads are the way to go when you have got that far.
A nasty, messy and thoroughly frustrating job.
William
