hs001jde
Good evening, I’m suffering from what seems to be a common problem, wet carpet at the bottom of my door card. I’ve watched all the YouTube videos I can find on how to fix the issue. I’ve removed the door card successfully, even managed to do it without breaking any of the clips! All the clips were in good condition and the seals were good. I can however see that the rubber seal that runs between the bottom of the inner metal plate and the outer door is completely perished and soaking wet. So I’ll replace this which seems easy enough. But what I can’t work out is how the water is meant to drain away. There a couple of holes just above the rubber seal so it could escape through them, so long as the rubber seal is water tight. If I replace this rubber seal will that definitely fix the problem? To me it seems like the rubber seal should be a last defence to catch any excess water and that there should be some other channel or drain to allow the water to escape quickly. Is there anything else inside the door that needs to be checked before I put everything back together again!
Thanks in advance
Thanks in advance
