Fitting a 3 Bar fpr on my 944T
944Scott
Question for those with one fitted.
I have had a quick look at fitting one today, I see it goes on the rear of the fuel rail but it seems my current one has a threaded fuel line connection as opposed to a push on style one (secured with a hose clip) Do I need a different fpr or should I modify the fuel line to suit the new regulator.
What have other people done?
First of all why do you need one? Are you now running a Dual Port Wastegate or extra boost? If the answer to these questions is no then you don't need one. A 3 bar is a bit of a fiddle. It makes the injectors run at a higher duty cycle than they originally would have.
How much Alasdair ? I need one for when I bolt my dpw in, so if Scott doesn't want it let me know.
Cheers,
Mike
Don't fit one until you have fitted chips etc as all you will do will make the car run rich,they should be fitted in conjunction with chips.
ORIGINAL: Frenchy
No worries I have all the bits here except for the additional gauges required for set up.
