Neil Haughey
A couple of questions for you boys well versed in the art of brake pad filing/grinding. I took my rear pads out today on the nearside to investigate why it was binding on on track sometimes (confirmed by another racer who was following and spotted it lighting up to smoke when I hit the brakes). TBH neither pad was that tight in that both came out easily using bent end circlip pliers. What is odd is that the outside pad was the stiffest, I took it out, cleaned it off then filed off the edges/burrs top and bottom. It had already been ground off before so just a clean up, pushed it back it which required a bit of force but nothing amazing but once seated it feels as tight if not tighter than it was before. I can pull it back off the end of the caliper plate and press it home again fairly easily but once seated its tight in the up down sense. I believe this is how its supposed to be? The other one was the complete opposite in that it came out easily but just wouldn't go back in so I set to it with the file and probably took off much more metal than on the backing off the outer pad. It was still a biatch to get back in but once seated it feels fairly loose and will knock up and down a touch, however with the retaining spring on turning the disk back and forth its not really noticeable. I believe this is not good and is an unfortunate side effect of my heavily corroded calipers?
BTW Halfords long nose grips are perfect for uncliping the retaining spring.
Still can't see why it was binding though as it has been free runnning ever since driving the car back home. I did note a chunk of material missing from the top of one of the pads, maybe this broke off in the race and was jamming the pad on?
