peanut
sorry to hear about your woes. Mine was off the road for 4 months over Christmas because I couldn't find a no start fault. Grrr it was so frustrating to know that it was probably something simple and obvious and I couldn't use the damn car.
Have you checked the door seals yet ? My Lux pass door seal leaked terribly. My footwell carpets were always soaking wet and with the condensation it was like driving in a sauna.
Also check the trim strips along the window glass. If rainwater is getting inside your doors it can find a way into the car when you brake. The water sloshes into the car from the bottom of the doors through the numerous holes in the doorsskins
A sign of leaking door seals is staining drips on the cills under the doors after heavy rain.
The most likely area to check is the front scutle. It hangs over the front footwells and fills with water whenever it rains or you clean the car.
I'd chuck a bucket of water into the scuttle and then sit in the car and wait[
