Fast response throttle cam-any good?
- Thread starter jwindwood
pauljmcnulty
stevie d
bmnelsc
ORIGINAL: bigdavec
or you could press your foot down further on the pedal.....
The good news with the Porsche mechanical cam is that you can change it back if you don't like the feel of the new one. A lot easier than changing Infinitis [
pauljmcnulty
I've got one of those fitted to mine. It was fitted before I bought the car so I don't know how it compares to the standard one. It does feel quite lively though.
The throttle cam fitted is just an economy model. The replacement was standard in other markets so it's not an aftermarket part that ruins the driveability or anything. It might seem a bit more on/off at first, but that would only be down to you getting used to the previous one where you need to really push the pedal to get through the "economy" setting.
andy watson
Moderator
simdel1
ORIGINAL: pauljmcnulty
Sounds good. I think I'll leave it on then!
Cost £0 Time taken about 10 to 15 minutes. And to change back, undo the spindle nut and reposition the disc, refit the nut, easy.
Buddy - Did exactly that for the 2.7 with a bit of trial and error to get the positioning of the hole correct.
Also have to raise the cam on the spindle with a couple of washer to get the (redundant) lever to clear the spring.
Will take a couple of pics an post later.
Edit- Where my current hole is is marginal for cable length,
If I were to do it again I would move it even further round.
I left the long arm on so I could swap it back if I didn't like it on this engine.
