Donald - does your car have aircon, if so you will need the 3 pin sensor not the 2 pin
Fan not switching off!!!
- Thread starter dgrewar
Hi again
I have been making short journeys (15 mins) with the relay out - wise friend told me this is ok? Thoughts....
Also, prised open relay and inside is beautiful. Should I wd4o the 2 contact switches, anything else. Also, how to best fold in the metal to securely close unit again?
Windscreen wiper sorted after squirt of wd40!!
Thanks in advance..
p.s. where would I find the rad thermo switch to check it...
Thanks in advance..
smiffyraf1
have you popped the contact off? when they stick they kind of solder themselves on so takes a bit of unsticking! i just bent the metal casing out with pliers and closed again with piers. still looks neat. In this weather it should be fine, just be careful about getting stuck in traffic
No problem running short trips this time of year.
Thermo switch is n/s of rad top under top hose and vent pipe to reservoir - absolute pain to get at!
Just checked - is 30mm spanner required.
