gajh
Hi All,
Me again!! is it possible to remove the inner exhaust header without removing the outer? the reason I ask is that I have taken the inlet manifold off and fuel rail and noticed that the injector on number two piston doesn't have its yellow end cap on and also that number two cylinder valves are open, which means if that end cap was on and has fallen off it could be in the cylinder lying on top of the piston. It maybe that it wasnt on but I should check to be on the safe side. So i am thinking with the exhaust manifold off I maybe able to see in the cylinder.
Gavin
Gavin
