ORIGINAL: zcacogp
Chris,
Looks fine to me. Says 3 inch height when lowered, so would fit under a 944. And claims a lifting weight of 2 tonnes, which is more than enough. Only snag is that the jack handle can only be used from directly behind; some trolley jacks can have the handle inserted from any direction.
Nonetheless, I'd go for it.
Ah, that could be a problem. The area I will use it is a bit narrow so would ideally have the crank handle from the side. I'll do a bit more searching!
