Engine stalls immediately after starting
- Thread starter Telster
Jonny944CS
Nothing major, but here's an issue I've had since building the car last year and I'm beginning to run out of things to try....
Model:
1984 944 2.5 8v
Issue:
The starter motor turns over and the engine fires as normal for a second or two, then dies. The only way to prevent this happening is to blip the throttle at just the right moment. The car will then run a little lumpy, then clear.
I'd say it is evident ~95% of the time (hot or cold). Once up and running the car performs and idles fine with no obvious issues.
Things I have tried to test:
- DME and relay
- Fresh battery
- Fuel Pressure Regulator and leak-down test (hot and cold)
- Flywheel reference sensors
- Vacuum Leaks
- Auxiliary Air Valve (appears to move with 12v)
- Coolant temp sensor
Any similar experiences and/or suggestions greatly received.
bmnelsc
Jonny944CS
Jonny944CS
Like [link=http://www.youtube.com/watch?v=-11J8XawQtc]this.[/link] I guess care needs to be taken so as not to put too much, or too little pressure on the track.ORIGINAL: A9XXC If the tracks are worn etc its quite easy to get the contacts to run on a fresh piece of track, just by moving the bracket up or down the spindle.
Outrun944
Jonny944CS
