Engine Oil
- Thread starter Billygoat
Call our forum expert 'Oilman' (Simon Barnard) at Opie oils 01209 215164 and he can advise you on specific brands and even some good prices for club members
John Sims
PCGB Admin
Several professional people I respect rate Castrol RS 10w/60. Oil man belittles this product as apparently it is too great an operating band which can only be achieved with using viscosity enhancers which are quickly broken down giving you 10w/50......but then 10w/50 works for me.[
Do not use 0w/40. It is too light - even if it will stay in the engine. A friend of ours had big problems with her 924 after "investing" in the lighter weight Mobil 1.
sawood12
Brace yourself for a couple of potentially daft questions:-
1. Why go to a 50 viscosity oil for tracking? Surely the thicker viscosity is going to increase oil temps through friction within the oil itself?? And cause more drag on the engine iteslf?
2. Why would your oil get any hotter than normal if you are driving the car hard on track - shouldn't the engine and oil cooling systems be adequate enough to control the temps?
1l per 1,500km is the upper end of acceptable oil usage, not the normal. It's unusual for a Turbo not to use any, but that's not a bad thing.![. [FONT=verdana,geneva"] [FONT=verdana,geneva"]](/forum/styles/default/pcgb/space.gif)
I suspect that if I got the leaks sorted I would not be using any!!
Richard
Norfolk
1987 951
oilman
I would probably use a 5w-40 synthetic and you will find those through the link below.
http://www.opieoils.co.uk/c-656-5w-40.aspx
Out of those, the best ones are the Silkolene Pro S, Motul 300V, Redline and Gulf Competition. The Motul 8100 X-Cess, Gulf Formula G, Fuchs Supersyn and Mobil Synt S are good, cheaper alternatives. The cheaper ones are mineral based synthetics that have been modified enough to be legally called synthetics. They should burn off at a slower rate than a mineral or semi-synthetic oil though.
sawood12
Your increased oil consumption since you've increased boost is probably due to one of two thing - either the increase in pressure differential across your turbo oil seals drawing oil though when on boost or more oil being drawn through your air oil seperator (AOS).
In terms of compression, the only time my engine was compression tested at around the100k mile mark the results fell within the 'Just Run In' band. I never got the actual results so I can't advise on the actual numbers, my specialist did it as part of the cars first major service after I asked him to give her a damn good looking over to understand what i'd bought. I wish i'd asked him for the results now.
sawood12
oilman
The genuine ester/pao blends cost a lot more and there is a good reason for that.
Guy
Copperman05
Edd
robwright
