I’ve a 997.1 4S and the engine fan comes on once it’s up to temperature and stays on constantly. If I park the car for an hour or so and start the engine the fan comes on straight away. This clearly isn’t right, has anyone had this problem and fixed it. I’ve changed the engine temperature sensor and it’s made no difference.
Engine deck fan stays on
- Thread starter Alan_Wiggett
If it was a boxster or cayman I would suggest that the engine compartment temp sensor has become dislodged from its bracket and it likely resting on something that gets hot.
I assume the 997 has a similar setup but since the engine is the other way around I don’t know where that would be on a 911.
I would suggest getting it plugged into some diagnostics with Porsche smarts and see what the reading from that sensor is - if it’s not “sane” then a sensor or mounting fault seems likely.
I've ran the Porsche diagnostics and the fault reported was the temperature sensor, which has been replaced, and still the fan continues to run.
What was the code reported.?I've ran the Porsche diagnostics and the fault reported was the temperature sensor, which has been replaced, and still the fan continues to run.
That is how it is meant to work.
The temp sensor picks up heat soak from the block, and with the current ambient temps it can easily kick back on again if there is a lot of excesses heat in the engine bay.
My fan was not working at all, turned out it was the 12v feed from the front of the power distribution block under the dash going to the relay board under the rear parcel shelf had corroded and snapped, this is where it is joined in the little black box attached to the side of the gearbox just next to the transmission fill hole.
So I have been doing loads of research on the wiring, relays and how the ECU works and what signals it needs to turn on and off.
But when ambient temps are above roughly 24ºc it is quite usual for the fan to kick in straight away, even after it has been sat for a while.
