One of the 964s I am looking at had its engine cover undertray removed for replacement of the clutch and flywheel and the seller says it has been left off and placed in storage. This, he says, assists with cooling and reduces the need for the fans to run so much. It also, he says, reduces the expense of having to drop the tray down each time (presumably for servicing?) and replace the nuts.
Is it normal to run the car without the undertray, presumably it is there for a reason? Maybe it is off to disguise the fact that the engine is getting too hot and the fans are always on?
The other thing is that it has not been rebuilt and has 122K on the clock. I think I read on here that Porsche GB rebuilt a lot of engines under warranty, but not all the owners took them up on the offer. Presumably I would be able to find out from them whether this had been done or not. Is the rebuild a once in a lifetime operation? Do ALL cars need this at some stage and say if it has been already been rebuit by Porsche in its early life, will it need it again at some stage.
I realise there are a lot of ifs and buts and it depends answers, but some indication would be helpful.
Otherwise, this could be the one!!
