Dave Wilkinson
I thought many of the 964 forum readers might be interested in my recent experience as I was about to leave for Silverstone yesterday.
For reasons that I can't explain I noticed that the pull handle for the engine cover release was bent so in my dubious wisdom decided to pull it straight. Bad idea!! The handle broke off from the cable inside the guide pipe!! I had no opportunity to do anything about it at the time so proceeded to Silverstone as planned. By chance I met Steve Brookes (brksy16 on here) who cheered me up no end by telling me that he had a similar experience and his engine cover popped up of it's own accord. In the vain hope that he was right I spend the day having occasional tugs at the cover hoping I was going to avoid a huge bill from somebody to get it open. No amount of tugging would shift it. So I though, when I get the opportunity I'd get a pair of needle nosed pliers and pull the remaining stub of the cable. That plan went awry when I got home to discover that the stub had withdrawn so far into the guide pipe that I could no longer see it!!!
I then spent much of the night convinced that the cover would pop open before next morning, leave the engine light on and flatten the battery to scupper today's trip to Silverstone. I needed not worry - no action during the night.
We left early this morning and I noticed less than a mile down the road from home the rear spoiler was sitting a little higher than normal. Aha, I thought. Maybe we're in luck. True to Steve's word, the cover HAD popped open. Just a normal jolt from the road was enough!!
Looking at the mechanism once we got home it seems a very clever bit of design which requires the tension on the cable to hold the latch in the "latching" position. When or if the cable breaks the latching slide is released completely allowing the cover to lift. Because there is an amount of friction between the peg and the slide it may, as in my case, take a jolt to free it. So, rest assured, if it happens to you - don't panic. It WILL sort itself out.
BTW, the replacement parts only amount to about £25 from an OPC so I'll happily replace the cable and handle knowing that it's less likely to break again anytime soon.
It seems that 91- cars use a 993 cable which seems to have an integral handle whereas -91 cars use the older design with a seperate cable and handle. I have no idea if the two are compatible though.
Thanks again Steve for the confidence building!!
Dave
Dave
