Engine Compartment Blower not working
michael.williams1
A few days ago I noticed the engine compartment blower had stopped working and, because the heat wasn't clearing when the car was stationary, it could develop a slight misfire. Can anyone help me by providing a link to a circuit diagram for the 987.2S or any advice on where to start looking so I can investigate this problem? I thought I'd start by disconnecting and testing the fan and if that's ok I'd try and find the temperature sensor. I assume there is also a relay located somewhere but my Driver's Manual provides no help on the location of this at all! Does anyone know where the sensor and relay are located? I did check the fuse in the driver's footwell yesterday and that is fine ...
Hi Michael,
For starters this link will give you an idea where to find the sensor for the engine compartment fan [R/H inlet manifold?]; not sure where the relay is located though.
Edit: I found this on Google, although probably it relates to a LHD car … but I’ve no idea which relay is #8!
Hi Michael,
Thank you Motorhead. I've looked at this today and have so far located the Fan Relay and Fuse which are mounted on a bracket in the left hand wheel arch of the trunk, under the carpet which was fairly easy to pull out. The 10 Amp fuse has not blown and I removed the Relay and tested it and that is woking too, so I have eliminated those. I also checked the 7.5 Amp fuse in the driver's footwell which apparently (according to the little booklet in the fuse box) feeds the blower relay and that was OK too. I was expecting to find some direct wiring continuity between the relay and the bower motor but couldn't establish anything. I will check again tomorrow as that could be an issue(?).
Does anyone have a wiring diagram of this circuit?
The temperature sensor and blower motor could be faulty but I can't see a way to get some power onto the blower connection without removing the motor itself.
