Engine build progress
- Thread starter TTM
Indeed K27 coldside with K26/8 250 turbo hotside 360 thrust bearing, old technology, but flows lots - Was on the car before Mr Peckham owned a 944 - If I had met him sooner it would be spooling much earlier! Oh and its still on there, car is untouched still, will hopefully get some time with it over the next couple of weeks, TonyORIGINAL: TTM Thanks George! No worries anyway, I'm not in a hurry. Tom, I think Tony is/was running a K27/8 on his coupé.
TTM
Well-known member
TTM
Well-known member
You've got to love the simplicity of making changes with the Vitesse setup [ORIGINAL: TTM With regards to the software I just switched to the second E85 map (+35% fuel) on the Vitesse chipboard and did a new fuel map with the Piggyback.
Blimey! Just imagine the performance from Thoms 3.0L engine on those sort of boost levels [8D]ORIGINAL: 333pg333 I have run over 2bar when a vacuum tube worked lose. I know Sid has used 35psi on his car.
TTM
Well-known member
TTM
Well-known member
sawood12
I've never liked NOS, it doesn't seem like 'real' power to me as you only get it in a few second bursts. Something like a high octane fuel lifts the performance of the car for a whole tank. I also hear its very hard to accurately account for in the mapping, but that's just what I heard.ORIGINAL: sawood12 With the only apparent disadvantage of E85/biofuels causing you to stop more frequently at petrol stations for a fill up, wouldn't a more elegant solution for those short sharp bursts of extreme speed be to run lower boost pressures (thereby preserving the engine and transmission) and using NOS?
