Not sure how you do it, and I see the manual doesn't give any clue. Do check the oil level regularly, I stopped doing so and the level dropped to the minimum after about 1500 miles. Mines used 2 litres in 4500 miles, which according to the OPC is what they would expect; it's to do with it being a boxer engine apparently.   But aren't they great?
			You are using an out of date browser. It  may not display this or other websites correctly.
Engine Access
- Thread starter turbodog
uknick
To look at the engine you have to      1. remove the carpet covering the engine bay.  Use a plastic lever to lift the carpet so as to avoid damaging the body work.  It is held in with a few tabs around the edge.      2. You will now see the metal cover.  Remove screws and voila.      3. Refitting is the reverse.         If you look at the Planet 9 website I am sure there is an article how to do it with pictures.      http://www.planet-9.com/
			Hi Guys,
Sorry if this has been asked a million times before and you are all totally bored with it, but I have just bought a new (to me) 2.9 Cayman yesterday and would really like to have a look at the engine!
Could anyone advise how to do this please (presume you need to take the cover off inside the car and it's not from underneath), but how is this done?
Just feeling my way around the car at the moment, just found out how to check the oil level last night via the computer which is a bit weird. Loving it all the same though.
Hope someone can help and sorry if this has been done to death in the past.
My apologies i think you are correct in saying thats a high consumption.  Its just the figure that Porsche give.  Obviously it varies and some will use less but Porsche do say that the said figure would be acceptible.       Been a performance engine they do burn oil compared to normal cars.
			I think you may get questioned on that statement! Previous car 1lt per1500 miles (Gen2 C2S). Present car 7000 miles and hasn't used a drop - apparently
