electrical problem
Check out Clarks garage to see which ignition switch terminals are involved and try a short across them with a lump of 6mm cable, not 2.5 etc because of the current draw, burned skin smells awful !
Have you cleaned all the connectors to the starter, solenoid and engine to chassis earth at the back of the block? Also clean the earth lead on the battery.
hi here we go again no power to the ignition turn the key nothing checked battery all good any ideas cheers
