I'm in need of some technical elecritcal help please!
Im having some issues with the headlight lifting, turn the knob and the lights light up but don't lift, also interior lights don't illuminate and fog lights now won't switch on. I have fitted a tested headlight switch hoping that would solve the issue and I have also just fitted a tested relay for lift motor. I have tested the lift motor and that works fine.
i had just finished of fitting the dash trim back on after re-coving the dash vinyl when I noticed the issue, I have removed everything again and checked all connections and can't see anything obvious?
the fog lights control and interior dash lights are all controlled from the headlight switch so was really hoping the new switch would fix it!!
any help would be greatly appreciated!!
Phil
Phil
