Yeah. Pretty sure this is the case.ORIGINAL: scam75
Can someone confirm that both seats should be on the same fuse?
Before you go suspecting the wiring, it is possible to plug the seats in wrongly; you can put the plug in such that the contacts are one row out, and then the behaviour of the seat is peculiar. Whether this would explain the symptoms you have I'm not sure, but it's worth making sure that the plug is aligned as it should be.
