EBC...
- Thread starter 944 man
PSH
Simon if you do a google search for these two main contenders you'll find lots of forums with comparisons between the two. One thing that you can't set on the avcr is road speed as it doesn't recognise the Porsche feedback. Personally I never found this a problem, I usually have the screen set at one of the other options, boost, rpm , both or more, iirc you can have up to 4 things being monitored on screen at once in either digital or analogue mode.
Which ever you decide on do get the DPW and a boost controller of some description it will transform the car. The 944 turbo in standard trim was handicapped by Porsche to begin loosing boost long before getting to max boost. At the time Porsche said this was to make it an easier car to drive and therefore targeting a wider market, those in the know will tell you this was to stop the 944 turbo from out performing the 911 turbo. In this they failed as Porsche admitted that the 944 Turbo was the fastest car in the fleet even with the handicaps.
To sum up, do the DPW mods and release the cars real potential , you'll never look back Simon....
Pete
944 man
ORIGINAL: Diver944
I found the Greddy profec Spec II fairly easy to set up once I'd found a guide on a Mitsubishi forum (of all places). It was useful to have the three boost settings - Off, Low and High and once set you can just forget about it.
MLR Paul?
Are there any article that anyone can direct me towards, which speaks knowledgeably about boost and fueling? Im particularly interested in what amount of air the DME is able to fuel, as Im reluctant to fit an aftermarket 'chip'.
Ed, for £200, surely an EBC has to be a no-brainer, even if I wasnt wary of Dawes Device type MBCs.
Simon
edh
I wouldn't be worried about aftermarket chips - I doubt there are many turbos still running standard chips.
I thought that if you wanted to run more boost (and hold it) then it was a requirement to change the DME chip? How about our new UK MAP based offering? Tom will know the full story I guess, but I was under the impression that the AFM maxes out at 5V well before the maximum air flow, so the fuelling relies on a map that is designed for a set boost level?
..careful with that headgasket [
edh
As for the headgasket, I would seriously consider it next time the belts are being done, as that is a large proportion of the cost. It's very annoying to get the belts done & then have a h/g fail a few weeks / month later. IIRC belts ~ 300, headgasket ~ 500 (at ph prices)
of course then when the head is off it makes sense to have the Lindsey steam vent kit fitted (see I told you it's a slippery slope.. [
As has been said, if you are going to change the boost then you need to change the DME chip.ORIGINAL: 944 man
Simon
At WOT, the DME just runs off a one line fueling table to deliver a set amount of fuel for the engine revs. It does not know what boost is, it assumes that it is standard for WOT at those revs.
The signal from the AFM does slightly scale that, but not enough to cope with a boost curve/level that is not the standard that the chips have been programmed for.
944 man
I was all ready to get it in their diary, but Im not sure what to do now. I may be a misunderstanding, of course.
Simon
Apart from taking the belt cover off, loosening the cam belt and slipping it off the cam sprocket, I don't think that there is much that the two jobs have in common.ORIGINAL: 944 man
Im having the belts changed as I need the front seals replacing, and this was why I asked about a headgasket replacement. Simon quoted me £340+ for the seals and belts, which Im happy with, and a further £420 labour to add the headgasket - or at least that was my understanding.
Simon
944 man
ORIGINAL: GPF
Simon
Thanks Graham. Initially I only wanted to get the car to do as Porsche intended, had the wastegate not been such a weak link, but turbo mission-creep has already started...[
If I increase the boost then I will change the DME & KLR chips, although Im not keen on being forced to use SUL either. The beauty of the right EBC, I think, is that you can set the boost to match the original boost map, making the car perform far better whilst still using the original fuel and ignition tables.
You said
ORIGINAL: 944 man
My aspirations are modest - Id like to get the maximum performance out of the car that the engineers intended, but Im not looking to replace the turbocharger. I believe that Bosch managed about 290bhp, before the wastegate was hobbled...
But the standard chips have been mapped for the wastegate as fitted - hobbled in your description.
So you can't get the 290hp you refer to above (wherever that came from) without changing the chips.....
PSH
ORIGINAL: 944 man
ORIGINAL: GPF
Simon
Thanks Graham. Initially I only wanted to get the car to do as Porsche intended, had the wastegate not been such a weak link, but turbo mission-creep has already started...[]
In the old days when doing minor mods and not remapping we used to adjust the ECU pototiometer to get extra fuel for more boost. Not good practise but at least you stop the engine going lean by adding +3 or +6 % of fuel. Will run very rich though and risk bore wash.
Don't worry about ' turbo mission creep' it's quite normal and only harms your wallet...
Pete
944 man
Never even fitted a boost gauge, and Im hoping to show similar restraint here...
edh
ORIGINAL: GPF
Simon
Ok fair enough if it's another £400+ If it's only £200 extra it's worth considering. I bet you'll need a headgasket within a year [
