ebay cars
- Thread starter 912UK
The gearbox pinion bearings complain a bit but they will whine for years
The interior suffers from split seats and cracked dashboards - seats can be refurbed but the dash is not easy to come by. If you ignore that this has happened - you will just forget its there [
Engine wise - one word "Bulletproof" but the Turbo and "S" models need to have a good history behind them otherwise it will cost you a kings ransom to put right. The tappets need adjusting and the timing belt needs changed but this is a very easy job as there is loads of room.
Usual look at springs/shocks/bushings and make sure they are ok...! If they are knackered then they are very easy got..!
If you get one for £250 then be prepared to spend a bit and get your hands dirty to get it into a good useable shape [
Northern924
Parts/panels can be expensive if you are buing new, but the reason mine took so long to get back on the road was that I was in no rush so just picked parts up from ebay or scrapyards when they came up in good enough condition.
The brake system only cost me £72 to replace everything, that was for shoes, pads, spring kit, tensioners, rear cylinder, all new brake pipe and pipe ends, calipers and flexi's were good so didn't any work.
Depends really on what level of finish you want I guess, mine is a daily drive, and will need a respray to get it looking better, but that'll be done sometime this summer I hope. but you could very easily spend £1000's on it, and risk not getting anywhere near yoou money, time and effort.
They are and for a while yet will be a cheap buy, but they are great value for money IMO.
On Sunday 6th April the Frontrunner event will be taking place at Cornbury House. Come alonfg and speak to the owners. There may well be cars for sale as well as the autojumble.
