EBay Aluminium Radiators
Wallachie
It looks like my Turbo needs a new radiator, an OE one is almost £600, so there is quite a saving to be had with this one.
Has anyone tried one before?
Well known 944 enthusiast has an OEM radiator for sale on Facebook marketplace for £325 -
Thanks for the reply, ad says he will only post to mainland UK, I’m in NI. Common issue these days post Brexit, posting to NI is a complete hassle with all the added paperwork required.
I've got one of these. Can be a bit tricky to fit, mine was slightly different dimensions to OEM. Had to modify the fan housing a little bit and lengthen one water pipe by an inch. Be careful with the screws on the fan housing so you don't puncture your new radiator! We had to grind them down a bit for safety.
Once fitted however, a great radiator and an upgrade on stock. Mine seems very well made and the car runs cooler. Done 17k miles without an issue since it was fitted. It's a no brainer as long as you are prepared for the initial issues to make it fit.
The fitting is documented in my engine build thread.
Stuart
