chrisg
Chris a few answers to your questions:
IMHO I wouldn't bother with them if you're checking the pads on a regular basis. All I'd do is ensure you leave the 'stub' or connector in the barrel connector thingy to keep muck out of the electrics, simply chop the cable off at the connector. I've had my Turbo like this for years - learn to live with the wear indicator red on the dashboard. Re-use of washers for caliper bolts: The washers for the caliper bolts are a bit warped. I assume I should replace these? I guess the bolts are cheap enough as well to be worth replacing? I would they're not massively expensive either OPC or standard metric bolt, not with the hassle of them getting stuck or rounded off. o remove the calipers I clipped the brake line with a brake hose clamp and then rotated the removed caliper until it came off the thread - nice. However, when I reverse the process with the new caliper on the thread fully it is not at the same orientation. To get the brake calipers on and the brake hose back in place as before I will need to either tighten the hose further in the caliper (it is not yet torqued but is reasonably tight) or twist the line somewhat. What should I do?? It seems like the thread on the new caliper must be start at a different angle to the old caliper? This is one way of doing it, TBH you're going to have to bleed the system anyhow, I would just disconnect the flexi line where it meets the hard line , connect it into the calliper then do it back up to the hard line and ensure it's not twisted. Do you lines have a small copper washer between the fitment and the caliper ? I've bought some yellow stuff pads, after much deliberating. I had green stuff pads before and had no problems with them (the way I drive) on track days until they wore down. I admit budget came into it! Anyway, although the slider plates on the new calipers look very clean (and new), the pads do not slide in. There is probably not much in it - it might just require removal of the paint, but I suppose I should take a file to the edges of the pads (the metal, not the pad material) until they fit? In which case, how freely should they be able to move? Should they be snug, so they require a bit of working to get them in? Or should they move freely in the caliper They need to be free to get in and out of the caliper, yes take a small file to the backing edge both top and bottom to ensure they slide in nice and freely. I should add that there are some subtle differences between the calipers - the old one had 'porsche' embossed on them, the new ones just have it printed. Also the hinged retainer for the pads folds upwards on the new ones - it folded down on the old set. Presumably these are just minor changes relfecting that the new calipers came off a younger car (an S2). Errr no..... Both the 944's Ive had (current 951 with M030 calipers) and an S2 (G reg) teh clover leaf folded upwards ie the pivot point was at the bottom. I would check both calipers for direction - the brembo calipers usually have an arrow showing the rotation of the wheel relative to the caliper - the bottom and top pistons are slightly different. Its vaguely possible that a previous/ last owner switched the calipers ? Just check that the bleed nipples are at the top of the caliper and the cross over pipe is at the bottom. If you need any assistance or want to chat happy to take a phone call ? 07540 193874 Yours ChrisWear indicators: The wear indicator for one pad has disintegrated. Is there any disadvantage to leaving these out? The pads are very well worn yet there is no wear indicator lit on the car. It doesn't seem to serve much purpose if you are in the habit of keeping an eye on your brake pad wear anyway.
