Driving across Europe
MaxGTI
Hi All - we are taking our 970 across Europe in a few days time. Does anyone know how to switch the headlight beam so it points in the other direction as per requirement on the continent?
I have checked the driver's manual and also Googled this issue but nothing has come up. After speaking with Porsche Hatfield, they advise upon landing in Mainland Europe, to take out the headlight and use the switch on the back of each unit to flip the beam over. Surely, there must be a better way.....? I really want to avoid using those stickers.
TIA
which type of headlights do you have on yours ?
on mine you go into setting and you can change from left to right driving this only happends on HID bulbs
I have the standard Bi-Xenons:
right go to vechicle menu then go to settings then to light and visibilty then exterior lights then go to L/R driving then select standard from the list
that should do it
from justin
TIA
If there’s no menu option then If it’s anything like the 987 the switch inside the headlights doesn’t “flip” them. It simply masks the near side flip up that we have in the uk. That’s the bit that will dazzle oncoming traffic when in Europe.
So. You can do the flip before you go - it doesn’t cause you to dazzle anyone in the uk. I do mine when I prepping the car for the trip ( fluids , pressures, etc ) the day or so before I go and I flip them back when doing the clean the insect off and take trip stuff out the car when I return usually a day or so later. Takes 15 mins,
My 996s with Xenons all had manual switches on the back of the headlamp casing (quite easy to alter) but on my 997.2 and 991.1 and Macan (still with with Xenons) it was all done through the “settings” menu.
From memory the steps are to select VEHICLE > SETTINGS > LIGHTS AND VISIBILITY > L/R DRIVING. Then select “INVERTED” for driving on the right. It’s the same on my 991.2 with LEDs.
You will also find that when you’ve got it set for driving on the right, when the headlights come on in “auto” setting you will get a yellow notification come up for a few seconds on the main instrument display, which is a bit disconcerting you’re doing 130kph (or more) and didn’t quite catch what it said…
I don't have a 970 but on other models of similar vintage it depends on the lights fitted. For example, on 981 from 2012 to 2016, the rare but standard (on base car) halogens needed the switch flicking in the back of the headlight, the optional (but standard on S) bi-Xenon lights (non-PDLS) were symmetrical and required no adjustment at all for European driving, and the PDLS lights can be adjusted to "Inverted" as per post #6 above. All in the relevant Driver's Manual.
