I have Recently encountered this problem when opening the drivers door the window drops then moves up and down again repeatedly I tried the re-set procedures of holding up down for ten seconds but the problem still persists. I also find that holding down the drivers window switch triggers the rear near side (passenger) window open! Similarly doing the same with the passenger front window triggers the drivers side rear window! In addition,the side door lights fluctuate occasionally when this sporadic window opening/closing occurs. It’s baffling as I don’t know where to start looking for the reason, micro switches I guess but I believe there are two in either door. The passenger door seems error free though. Any ideas as to what could be the cause?
Thanks.
Stuart.
