drivers door wont open
- Thread starter Guest
Fred Hindle
Had a problem with one of my doors. The rod that is attached to the inside door opener had come detached from the lock end. It may just need clicking back in position and the locking piece putting back on.
If the locking piece has broken then can be repaired using wire.
The outer handle presses down onto a lever on the locking mechanism so you may be able to find that and release the door.
If you do the job without cutting yourself you will be lucky.
Cheers,
Fred
Fred Hindle
It needs to be pushed down.
Cheers,
