Door Hnadle Tidy Up
- Thread starter robwright
bennyboy
http://www.gatebil.no/forum/viewtopic.php?t=9153
pauljmcnulty
cococola
I carefully primed and resprayed my handles with satin spray about 12 months ago and was really pleased with the finishing result[
You can either remove the handles or cheat like I did by masking the body around the handle and then paint.
Had a day on the old girl on friday, new v belt and power steering belt, oil and filter, new oil seal were the oil cooler pipe exits the diiff to sort a leak, sorted a power steering leak.
Then went about sorting a blowing exhaust in the wastgete area, ended up with a strip down as some lazy bassttard had not botheed replacing the wastegate hanger bracket bolts which in turn had caused the pipe from wastegate to turbo to fracture , bit of welding some new bolts gaskets and crush rings and "jobs a goodun"
Lost all feeling in my toes though !
Roll on summer [
I believe they are from an Audi 80
Those handles are Volvo items.
Easiest way to go is to install 968 handles for better looks. If original ones (with Porsche script) just have them re-anoidzed, will cost few £ and looks like new.
Fat Albert
