Door Handles
- Thread starter berg944
From there I can't remember if you can disconnect at the top of the rod or at the bottom but if at the top try not to let the rod drop out of sight or it is a case of door card off, not difficult though no airbags as on later cars.
If you do have to access from below inside the car the internal mechanism and bracket make access to the rod difficult.
aporschefan
The car has central locking. Does that make any difference?
stevie d
picopro19k78
Its a fiddley job and need patience. If you are replacing the gaskets you will need to remove the plastic ball on the lock inside to slide the rear gasket on.
You will need to remove the door card and make sure you fit the lock balljoint first and then the central locking plastic small internal rod and the the central locking rod to the solenoid.
If you don't put the balljoint on first you won't be able to get enough pressure to pop it on.
It took me 2 hours to find this out by trial and error!!
Good Luck
bumperblue
I did this and once you remove the door screw and slide the handle back and out, it gives just enough clear air against the door so you can slide the gaskets over the handle without removing the solenoid rod. The gaskets are reasonably pliable. I would also suggest putting tape around the door were you think the handle will bang against as you fiddle around, you don't want any scratches. Ian
You can buy lock components from OPC my handles are scripted so luckily i will not have to look for another but repair this one.
Masking tape all over my door to protect, do this as you WILL scratch the door.
Mark they must have had the door opened to remove the securing screws as there is no way they would budge without these being removed ?
Chrishazle
https://docs.google.com/open?id=0B3FX3V_kb7JvNmEzYWFiOWQtNDliNi00YzIzLTk3OGUtZmQ3MWRkZDNkMzYz
PSH
Volhv_944
User
Are we talking about the "trigger" on the door handles that breaks? If so, you can just swap the VW trigger over to the Porsche handles. That's what I did to mine.
Another thought would be to use the VW handles for the back, off 4 door cars. it would do a slick door lock delete if you have remote door locks that is.
end quote:
so it seems that it is possible, has anyone here done this and if so which model year golf handles did you use??
cheers
Pete
BoxsterBox
I still own a 1985 VW Golf GTI Mk.2 that I've had from new. I think the Mk.2 door handles are identical to the 944 handles. Have a look at this link giving an exploded diagram of the Mk.2 door handles and Fitting Parts which may be helpful.
https://www.vwheritage.com/mk2-golf/mk2-golf-body-trim/door-handles-locks-check-straps
Good luck! Simon
PSH
Thanks for the link..
Pete
