Door handle issue
- Thread starter SUSIT
WBray
ORIGINAL: colin944
Handle pulls or pushes a rod with a ball ans socket joint. Check it's not just popped out. Motortune always gets a good name. what do you need done?
Thanks for all replies,
A few things starting to pile up at present, but a good service oil, plugs, dizy cap, gearbox oil and a few other bits and bobs, use to do all my own work as had decent garage and equipment but its kerbside motors these days and one its too cold and two I am getting too old lol. looking at the cars history i think they have worked on it a few times in the past. Have yet to find a local company I trust, last one i tried wouldnt even look at it.
Will take door card off when i get a chance, gave me an excuse to drive my white one tonight, only got couple weeks left before its MOT is up and I reckon its the end of the road as sills need done. Sad but nothing lives for ever
Suffolk944
Moderator
924nutter
Chrishazle
https://docs.google.com/file/d/0B3FX3V_kb7JvNmEzYWFiOWQtNDliNi00YzIzLTk3OGUtZmQ3MWRkZDNkMzYz/edit?pli=1
ORIGINAL: Chrishazle
If the innards of the 944 doors are the same as a 968, this may help :
Thank you kind sir
That a very useful guide if its the same, cant see a great reason they would significantly re-engineer for the 968
ChasR
On one side I popped it back in for now, although it is slightly loose, with the other side having completely broken up. New operating rods later and I have a set of working doors
Sure enough it was the cast alloy link that transmits movement from the door handle push button to the door release linkage snapped.
Firstly if this is the cause of your failure DO NOT remove the door card as you will still not be able to access the door release mechanism - I did this & only made more work for myself
& ended up with scratched arms & knuckles.
After trying on & off for two days to get to grips with this I finally admitted defeat & called my local independent Porsche specialist, (Northway, always very helpful).
They advised that it was a tricky little job which could take 20 min 0r 2 to 3 hours depending how it went.
Work could all be done by just removing the door handle & working with long series snipe nosed pliers - combination of straight & curved.
Actually took about 40 mins but I think I just got lucky !!
Top Tip - Tie a piece of cord or fishing line around the new part, makes it far easier to retrieve it if you drop it into the door innards
