Door Cards (wanted)
- Thread starter 944 LIL
Black Beauty
Ta
BB
944 man
ORIGINAL: A.Wang
I might do, on the basis that the armrests won't fit with the full welded-in roll cage in place. I need to confirm what the boys are doing for door cards first, and let you know if a set of all-black ones would be available.
Id talk to Kev about the carbon fibre ones he has...
As a suggestion, it would be fairly easy to recover the door cards you already have. I have made them for previous cars (Mk1 Golfs), but they are very easy because they are flat. If you were stuck you could recover the bottom of your door cards - the flat bits - with some careful gluing or stitching the new cover along the join with the top of the door card.
It's something I am seriously considering on mine.
The alternative option of having carbon fibre door cards installed is a bit too expensive for me to stomach at the moment. [
944 man
ORIGINAL: A.Wang
Colin, I've just confirmed that only the armrests are coming out of the car, the door cards are going back in, so unfortunately mine won't be available.
The alternative option of having carbon fibre door cards installed is a bit too expensive for me to stomach at the moment. []
You could ask again: I noticed that a number of prices were mentioned: some starting £1xx:00...
ORIGINAL: 944 man
ORIGINAL: A.Wang
I was quoted £440 for the pair...which right now, is much better spent on other mechanical bits for the car!
944 man
these are the very chaps....
pm me please !!
Tried to PM you, but message does not managed to go to you.
Peter Empson
ORIGINAL: 944 man
I can put you onto a firm wholl supply you with a pair of carbon door cards for just under £100 delivered.
Sounds similar to what I'm working on, although at that price those sounds remarkable value. If each door card is approx 1m by 0.5 and it's made from 3 layers then there could be 9 metres used for a pair, if making them yourself the carbon would cost more than that retail price (I think I pay in the region of £15-20 for a metre of fabric, albeit bought in small quantities).
Btw if anyone knows of a source of offcuts of aerolam or the carbon topped version (whatever that's called) please let me know, I want a small piece for the passenger footrest.
944 man
Simon.
Peter Empson
