david924s
ORIGINAL: Paul190H
Ok so i'm going down the used route I think. Just purchased a relatively low mileage (reputed) S2 head so i have cams and valves. My guy is going to get the valves re-profiled and I'll re-use the cams with all new chain, guides and gaskets etc. Might look at polishing the inlet tracks but the car is not going to be tuned so not sure there is any gain by just doing that?
I assume the cams sits in schell bearings and these would merit replacement?
Thanks for all your input.
Byy now you should know the cams don't sit in shell bearings so remember to check the cam supports for wear and ensure the cam journals are put back into the same position on the head they should have numbers marked on them to help.
