Dashboard rattle
lmellman
Hi,
The extended leather dashboard in my 2018 Cayenne was replaced under warranty by Porsche a couple of years ago. It has now developed an irritating vibration noise from the front centre area by the windscreen. The noise stops if you push the piece down. Anyone come across this? Is it just a question of packing it with rubber or foam inserts? Porsche Hatfield want £302 for the first hour to look at it! Photo attached
Sounds like a common issue after dashboard replacement — the trim may not be seated tightly, and a small piece of foam/felt tape or rubber padding in the right spot often fixes the vibration. I’d check the clips and mounting points first before paying Porsche £302 just for diagnosis.
