Shane Hodges
It's time for the 24-36 monthly geometry check and, given the positive things I have heard about Center Gravity, am looking to use them. However, given that they will also do corner weighting, they will possibly spend a shed load of time (and hence my cash) taking off dampers and freeing collars etc to adjust. Now 13 years and 62,000 miles means that my shocks have probably seen better days, but I like the ride and don't want things too stiff or fully adjustable for my reasonably fast road driving and 1 track day a year max.
So, any advice on the following would be much appreciated.
1) The dampers might as well be changed and Bilstein HD's seem the recommended way forward - I guess no one has any comments on this suggestion !?!
2) Springs. I have a standard set up and wondered whether to retain the current springs or replace. H&R have been mentioned on numerous occassions in the past. Is it best to replace springs too or will the old ones suffice? ... and what is the latest recommendation to keep things the same rather than stiffening things up?
3) Anti roll bars - I guess I do not need to change these given I am not playing with ride height or looking to change the current handling characteristics? (I understand standard bars aimed for moderate understeer.) Or do I?
4) Springs coming out of collars with Bilsteins when the car is jacked up resulting in MOT failings .... I remember this discussion sometime ago but cannot recall a solution. Was there one?
5) Have anyone used Centre Gravity for suspension work in addition to geometry work? ... or do you all just do it yourselves!?! I am wondereing whether I would be better off going to JZ (who regularly service the car) for the changes to the suspension or whether Centre Gravity has this experience in spades.
Many thanks in advance for any help, suggestions, comments, views etc etc!
