T911UK
We compared a set of OEM 997 discs with a set of Genuine Porsche discs last week. As soon as they were out of the box you could not tell them apart. The Porsche ones have no additional part numbers or makers name stamped into them, the label is on the box. The Textar brake pads are also identical to the Porsche ones aprt from the Porsche ones also have their part number printed onto the back in black ink. They both have "Textar" and "T401" stamped into the rear. Brake pad wear sensors have no markings on them, anti squeal pads have no markings on them      A complete set of OEM discs, pads, shims, sensors and bolts can be bought for £220.00 + VAT for the front and slightly less for the rears. DIY fitting easy enough, or any decent mechanic should be able to do it in about 5 hours max. £1500 is just crazy, it can be done for £700 + VAT
